SmartWerks
pre-moderated
- chester
Already told you how to check. And 13amp on 3hp often trip.
Thanks guys, I'm feeling a bit more optimistic about this now.
I'll grab a 16amp commando plug and socket this week and rig that up, but I think there's a fault somewhere as the motor just twitches a bit before poping the fuse.
What do the brushes look like? If they were worn badly then you wouldn't get the power and I think it would draw more as well.
Not all AC motors are brushless Richie. A lot of universal motors are used as they're cheaper and they definitely have them.AC motors don't have brushes.
Good point Wilbur. I blame not realising that on the fact that I'm an incompetent moronDead right. However, the OP did say he'd 'disconnected both capacitors', which assuming they're start/run caps does rather imply it's an induction motor rather than a universal in this particular case.
eSCHEn - No you're not. You are an enthusiastic amateur - like a lot of us.
What a very kind way to put it I am indebted sir xenthusiastic amateur
A capacitors resistance changes with the supply frequency* (or something like that), so there was probably little point measuring them.Run cap (200 uf) went slowly from high to low meg ohms. I think
Start cap (50 uf)went almost straight to 0.5 meg ohms.
I like your explanations Wilbur - they make sense!That last bit is only sort-of true. If you measure with a meter (on ohms) then the meter charges the cap up with the meter's current source. At first, while the cap's discharged, lots of current flows (and the voltage across the cap is low) so the meter indicates that you have a low resistance. Gradually the meter charges the cap up, so the current falls, the voltage rises and eventually the meter should think that it's seeing an open circuit.
The time this takes to happen depends on the relationship between the meter current source (which you don't generally know and might change as it re-ranges anyway) and the capacitance of the cap.
So you're right that it's nigh-on impossible to *measure* the capacitance of a capacitor using a meter on ohms, but you can often get an idea if it's working a bit. Like you say, a real capacitance measuring device would use some kind of alternating current.
