360 lbs is the pedestal, it is a bench mount. So should be ok.
i was looking at https://www.model-engineer.co.uk/sites/7/images/member_albums/55654/659574.jpg, so am not sure.ng! According to my 'hand book' a 2
is 380LB gross plus 150LB for the pedestal stand.
........................There is good news and bad news: the upper arm for the horizontal mill could not be found though the shaft end mounting and some tools were all there! The good news, one or 2 bits of tooling etc came with it:
Thanks, I will call them tomorrow.Not currently pictured on their site, " quillstar.co.uk " had a pallet with a number of Centec parts on it; not sure what model, but I seem to recall there was an overarm as well. Might be worth a call or sending an email ?
It needs opposite directions between using a vertical and horizontal head to get the correct direction of rotation in each case.Why the reversing switch? Surely it should only ever go one way? I foresee some nasty crashes if it doesn't!
That's odd. Mine had a different vertical head, which I never managed to identify, but I'm sure it turned in the right direction. I certainly never had a reversing switch anyway!It needs opposite directions between using a vertical and horizontal head to get the correct direction of rotation in each case.
I read it on http://www.lathes.co.uk/centec/ "As a point of interest, when a Centec is changed from horizontal to vertical drive the spindle will, unless the motor is fitted with a reversing switch, turn in the wrong direction."That's odd. Mine had a different vertical head, which I never managed to identify, but I'm sure it turned in the right direction. I certainly never had a reversing switch anyway!
