Tom Orrow L
- Shropshire, UK
Jonathan is occasionally meetings but he's usually pretty good at following stuff like this up, i'm sure he'll call.Called them this morning, still awaiting a phone call back from them.
If you pre set it with the pedal unplugged then plug it back in what do you get. Ignore the display. What does it put out.
Jonathan says -
'when using a foot control you are putting the machine into manual control and doing everything yourself with regard to start current end current etc the only option is to limit the maximum current with the trimmer on the side of the foot control. Setting this is proportional so min to max is 10-200A some half way will limit to 100A etc thats the only way you can set it off line.'
Are you sure? This is a different problem then. Can you look at the display and see it reading 200 amps.I get that Richard, and have tried that as previously stated.
Set Machine to 80 Amps, Set pedal (Unplugged) to Maximum, Plug in machine, go to weld, certainly not 80 amps, welding certainly towards 200 amps
When plugging the pedal in, this over rides the setting on the panel when the pedal is plugged in.
Yes I know mate but mine is overridden by the victor(isum). Although lorch built the machine it's adapted by victor to take there 7 pin plug and like the thermal arc machines it's got there software in it to make it behave like this when it recognises a remote. Mines a tweco arc master 220. (Black lorch)Richard , on the Lorch HT with SSC pedal you can change amps via the control noob on the machine and that setting is what the pedal gives you....never have to unplug the pedal to change the Amps, you just dial in the max you want on the front control panel and that's the max you get from the pedal.
Ok. What about this then. Open up your pedal and have a look at the main pot. Get the value off it. 5k,10k etc. Then do the same with your old pedal off the eastward. If they are the same you could then doctor the Eastwood pedal to work with the parweld and see if it works as you want it too.thats the ONLY gripe i have with the machine, is the fact the pedal over rides the machine. I'd rather set my amperage up via the front panel, which is at a nice height when im sitting down (hence the new fancy Trolley i made)
The fact you have to press the pedal, activating HF and Gas flow, to set the amperage on the pedal knob. just seems backwards and wrong.
I'd rather have a pedal with no Amperage knob on it at all. I want to control it ALL via the display panel.
