Noods
- Ipswich
Hi..
I've an annoying compresser fault where apon start up it blows the plug fuse.. It's a standard 13 amp fuse. I've found the only way I can overcome it is to initially drain the water from the tank and get the pressure low, then she starts up fine and will cut out when it reaches pressure.. If I initially start it up without draining the tank the motor struggles to turn a couple of rotations and then the fuse blows.. I've checked obv things and can't find anything yet.. When it reaches its pressure and the auto cut out kicks in you can hear the loud pssst of air etc.. Oil is fine, filters clean and have run a metre over it looking for shorts but nothing.. Normally she runs fine.. It's a Clarke 2 hp model only 16 months old and light use only..where the power comes into my workshop there's a trip box setup but it's not tripping everything out, just the plug fuse.
Appreciate any clues..
Many thanks
Many thanks
