How does that work then? Once the oil has warmed then the compressors generally seem to work ok, all things being equal the ambient air will not have warmed up at all (your still sucking air in from the same place...) - if your theory was correct the compressor would still not run even when warm?Nothing really to do with the oil, this is mainly an insignificant factor in most cases.
Problems are the design of the systems, particularly with the cheaper direct drive units as they are marginal at best; the real issue is air density, air is more dense in winter or when it is cold and the denser the air the more power it needs to compress it to a specific volume and pressure. In summer or when warm its density is reduced and normal service is resumed.
... The water droplets are sprayed in to reduce hot spots which in turn reduces detonation, nothing to do with steam whatsoever..
surely the oil is just a splash bath principle so would it have that much effect
It is 'ALL' about the oil, and is the main factor----------has been proved year after year time to go to new lower viscosity oil funny thing on saturday my standby tyre blower ( allways switched on 24/7) had tripped the amp switch and didnt start and was thinking I need to change the oil and thought I wonder when the first post would hit !Nothing really to do with the oil, this is mainly an insignificant factor in most cases.
Is it that time of year so soon?
Is it that time of year so soon? my compressor wont start month, sometimes called november or december ??...
BS has it right, thats in the summer but this time of year it can go for much longer especially on a 'throttling extension'starting amps on the motor will be about 50 for a couple of seconds
what about a diesel then ? aint no fuel in the air, fact is cold air is more dense. therefore more compression.Combustion engines use cooler air more efficiently with fuel droplets clinging on to the cool air..
has bought a new 1ph !! unit again even though they have 3Ph in the place ?? well I did try to educate them but ??
HEHE Spring ---------Thats Capacitor or amp switch month! coz they are tired after the winterthey won't start because the motor cutouts fail due to excessive use during winter.
You're having a laugh surely? It's oil viscosity why do you think there are various grades ? Even cars need thinner oil below a certain temperature in winter, it's well documented on here about temperature problems in winter also warming the pump cures the problemNothing really to do with the oil, this is mainly an insignificant factor in most cases.
cold weather thick oil = hard starting load . nothing to do with compression
