the snooper
getting older by the day
- Hull UK
No chance what so ever, nonsense , with your theory, once the motor is upto speed the compression will be that great it's gonna do damage to the pump so we better not use compressors in the winter, also warm air can carry more moisture then cold air so on a hot humid summers day where does that leave your and @Mee 's theoryToo prove it fill a cylinder with air and you will be able to rotate the flywheel by hand.. Now fill the same cylinder with H2O .. Water, you will not be able to turn the flywheel, and that's exactly the issue for the little compressors electric motor, trying to turn over whilst up against all that moisture ..
