Onoff
- Sevenoaks, UK
Taking a rest from cat tree houses.
Enough "teeth" do we think?
Not sure those teeth will survive...but then again apples are quite soft I guess. Maybe you could you add blocks of something on the inside to stop them twisting off?
I remembered right after postingWell it's going to be filled with concrete...
Could you put the screws into dowels or long Rawl plugs?...that way they'd be replaceable after the cement goes in.
you want all of those screws out and replace with full thread all the way down the screw and then you just want the head to be outside of the drum so it acts like a tooth scraping at the apple in chucks just like a wood planer does
no leave them on as they act like blades or in lathe terms carbide inserts
if you pull that bar out and screw in screws along its length in 4 places they will lock that bar to the concrete when its set
I would instead use stainless tube and drill holes for pins to be welded in.
Would 50mm stainless work? I'll be able to get a few lengths next week.
Had a thought, aluminium is generally considered food safe. I have a load of those laughing gas bottles looking for a project. I seem to remember they are quite thick wall and suitable to be tapped for M4 or M5 threads.
1mm sheet will do the same and fold it like copper roof folding method will do the trickSo would I but I haven't got any stainless tube.
