I used aralidite to glue together the split. I also spread some resin around the handlebars, to see if it prevents them turning. The existing bolt now provides insufficient pressure to stop rotation. Once it's set, I'll use wire and/or fibreglass to lash together the handlebars and the main part of the broken stem.
I was going to try TIG welding until someone said it's the wrong type of aluminium.
Hmm,no contact from George, do we assume he is in bed eating through a straw? How is it going George?
Without wanting to go as far as destructive testing, do you know of any simple tests I could run on the welded front forks, either before the forks are mounted back in the frame or after the bike is rolling again? Perhaps there aren't any, and any extra stress could just increase the risk of the forks snapping at an unexpected moment.
You could try setting up an easy deflection test for the fork, you don’t have to over load the fork just take it to a point where you’re happy with it.
I've had problems with my joins using quality materials
hw many weekly miles will it do roughly?? will you be doing any wheelies or bunny hops or anything like thathaha
