C
Chris Stevens
Guest
Thing is I don´t actually think it costs the body shop that much more time and materials to do a half decent job. I might not have expected an invisible butt weld but if your going to just patch over a heavily rusted area it doesn´t take very long just to cut out the worst parts - the metal is already thinned and looking for an excuse to be broken off. It doesn't have to be neat - even easier if your in a garage with a lift. Likewise on that floorpan the holes were drilled - someone just couldn´t be bothered or forgot to weld in the cross-member. The whole crossmember can be bought for 75 quid from Moss so its not like it was an unobtainium part that had to be hand made.
No professional is likely to bother doing an MOT repair to the same standard as proper restoration work, as firstly the customer wants the work done as cheaply as possible (resto standard might take 3 times as long), and in many cases by the time of next MOT, the rot will have become a great deal worse, and the car may well be scrapped unless its something like a Beetle, MG, Type 2, or anything else along the same lines.
Repair work on MGs is very time consuming to do properly, and if the customer pays for a cheap job thats exactly what they are going to get. I have done a few, and would say if you are looking at something which is very bad, then restoring it to a good standard isnt likely to be that much cheaper than a new shell, which is obviously a lot less susceptible to rust than a repaired original.
