123hotchef
- Kent
sold!Touch a piece of wood at anything above idle and it just pulls itself in and chomps through it.
XP`s are top drawer, a bit overkill for occasional use.
Bob
ok before I dive in balls first! Can I drain the tank on this and run the carb dry? If so how @sako243 I would rather cut this oak up on site than at my own house on the driveway! it gets messy quickly! I would just split it at home.Hayes Machinery were cheaper by a big margin on the 562XP when I got mine but they did have a sale on.
At least on my strimmer it's been a damn sight easier to start by draining the fuel and running the carb dry. I was planning on doing the same with my 562XP but it's been used pretty regularly at the moment so can't really comment...
no I cant face that with all this oak, I have done in the past but splitting it with the axe is exercise enoughI cut a load of free firewood up wth a 3ft ex swedish army bow saw. Like a hot knife through butter. Not to everyones taste but you use what you've got.
I would also add to Bob's comment above, the 562XP is the first tool that has genuinely scared me. I've always had a healthy respect for power tools - particularly grinders and chainsaws but this is the first time I got a big shock when pointed it at some wood. As the chap who helps my neighbour out with his carpentry and roofing business, it just wants to eat wood. Touch a piece of wood at anything above idle and it just pulls itself in and chomps through it.
I think the main difference was an aggressive chain rather than the dulled "home-user" ones, this thing chucks out shavings rather than sawdust. I've got over the initial shock now but still treat it with a very healthy respect, particularly as it revs so damn quickly compared to all others I've used. Easy to make a slip in this weather and you only need to touch the throttle.You should try a 372XP, with a 8 pin ring with a 16inch bar...![]()
Just run it dry, tanks are small enough, after a few days youll learn how long a measure of juice lasts.ok before I dive in balls first! Can I drain the tank on this and run the carb dry? If so how @sako243 I would rather cut this oak up on site than at my own house on the driveway! it gets messy quickly! I would just split it at home.
Maybe on smaller saws but my 562XP ran for the best part of half a day when I felled and logged a fir tree in the garden. Bearing in mind I didn't much need to go above half throttle a lot of the time and it revs so quickly that you don't keep it running whilst moving about limbing the tree.Just run it dry, tanks are small enough, after a few days youll learn how long a measure of juice lasts.
hum well just googled it! not cheap but is it made from the good stuff? I guess we will never know thoughNot sure - treated mine to some Aspen 2, 5 trees (proper ones not these little 8" tiddlers) in and still got a little bit left from 5l.
I have a gennie, I was going to sell it as It has only been used once! decent bit of kit with 16amp sockets too.i just use an electric chainsaw with an 60 meter extension lead any further just put the honda generator on the sack barrow and take it wherever and it will run as long as you want a bit of trimming and the battery one will be ok
Use aspen fuel or similar rather than pump fuel. Helps a lot with tools that aren't used regularlyI have the corded makita one for home use.
this would be for away from home use! like cutting this oak up into managable bits. It would also be handy to take out green lanning.
what would the maintance be like on the 562 if it was not used often?
It does look like a great bit of kit and I do love the smell!
Husqvarna 562 XP Mark II Professional Chainsaw
The Husqvarna 562 XP Mark II Professional Chainsaw is a top-notch 60cc chainsaw designed for professional hardwood forestry. With the ability to use a 28-inch guide bar and featuring AutoTune 3.0 with Simple Start Technology, this chainsaw makes starting and running in all conditions effortless.www.sam-turner.co.uk
not that bad actually if u factor in fuel costs oil costs and mixing
