On a recent long climb the engine got hot (did not actually boil) - the bottom hose was too hot to touch. After a few minutes idling with the fan on, hose back to just warm.
this is very true!Cooling is working but a bit marginal on hills. I spoke to my radiator shop and they said that a re-core would help - the quality and efficiency of radiator cores has come a long way in the last 50 years. I may get that done over the winter.
Rain water caught off a plastic sheet or non metallic or cement tiled roof is also fairly soft water .. filter it through a fine cloth o remove any crud before you pop it in the cooling system . I have a 310 litre rain barrel to play with if needed .One of the biggest killers of radiators is the habit of topping them up with tap water, whether mixed with anti-freeze or not.
It's a haphazard affair, as most people don't know or care about the quality of the water coming out of their tap, but given the likelihood of hard water being introduced to any given old radiator at some or many times in its past, it's quite possible that scaling up has happened.
This is why I've been keen to find sources of soft water local to me, and have developed the habit of storing the condensate from my dehumidifiers. It soon adds up and right now I've got enough to refill a dozen cooling systems.
We're lucky up here, no scaling from our soft water - that's also why whisky is good for you...in moderation
Never seems to need topping up anyway, so I'm lucky on 2 counts.
Our water used to have a slight brown tinge from being filtered by peat, then simply run through filters to remove any contamination. It tasted absolutely beautiful, then the 'safety' crowd got on the case and spent millions on a water-treatment plant up in the hills, pulling water from a loch. Sadly they overlooked dry Summers and their intake pipes didn't reach the water when the level dropped through evaporation.Cue much more expenditure with bottled water deliveries for weeks. You couldn't make it up.
The installed 'automatic chlorine dosers' which used to go in the huff occasionally, rendering the water undrinkable - cue more bottled water...... Eventually it all seems to work OK, but in no way tastes as good as before.![]()
Wanna buy a steam activated charcoal element with ultra violet light filtering system to remove 99.9% of all contaminants from your drinking water . ( You can't store the filtered water for more than 2 days in the fridge ) ?
Myles as a quick fix ..... have you tried cleaning he cooling system & back flushing the rad yourself ? One ounce of citric acid crystals in a pint of hot water poured in the rad . run the engine for 20 min or so to get to working temp for few minutes to mix the citric acid solution & get it all circulated . Leave it overnight .
Do a 20 min run of the engine in the morning to loosen any crud then turn it off & drain the rad Now back flush the rad from the bottom hose for a few minutes.
It's handy to make up an adaptor to pipe the dirty water off from the rad filler neck . Let it cool by itself for a coupe of hours then refill the rad adding a small 250 ml can of radiator weld just incase you have un blocked a tiny leak .
Often people take a rad to a workshop for it to be cleaned but forget that the block is also likely to be silted up or have flow rduced due to mineral deposits in the coolant and / or oil from the occasional partly blown head gasket .
I can't remember if you sprayed the rad with something like Gunk engine cleaner from both sides left it for a couple of hours and power washed it out with warm water from the engine side keeping the lance nozzle at least 15 inches from the cores . Then using a bit of thin plastic cut to size redress any bent over fins if possible .
One other thing that came to mind just now . Have you actually checked the temperature & operation of the thermostat using a bucket of hot water and a thermometer or isn't there one in the system .
