Dcal
- Antrim Northern Ireland
There should be a one way valve built into the radiator cap.
As the system cools the water contracts and causes a partial vacuum so without that valve, or if its faulty, the hoses will collapse.
Try and new radiator cap and check that it is the correct pressure rating.
Do you lose a pint of water every day or do you lose a pint of water and top it up and then lose the same pint the next day (if you know what I mean)
If the pressure rating of the cap is too low, or if the cap is faulty, you could easily lose a pint of water.
The caps and the cooling system are easily checked if you have access to the kit, any decent garage should have it.
Cap are (or used to be) cheap so people just changed them but testing it will confirm or eliminate it as a problem.
I'm not sure (it's been 30 years since I worked at a TK) but I think the cap should be 15psi. If it is not making the pressure you will you lose water (if the pressure can't increase the water will just go out the overflow)
Are you sure the heater needs bled? If it is working it should be OK.
I don't remember them being tricky to bleed. It might be symptomatic of another problem.
Does turning the heater on full when you starting to overheat reduce the engine temperature?
If you have a problem with air in the system the heater will be the first thing to show you have a problem.
e
