500e
Always buy fire insurance a flood is a hard start
- South West
Reckon the bearing is held in by plate & screws, it looks like a dimple at the top of housing where screw may be.
As you found the shaft is soft I would try the pipe over the shaft & pull, did it on a bench drill motor that was nearly as bad, 2 pulls a bit of luck & about 1.5 thou run out, what's to loose
