olek
- Paris, France
can you tell me an amp proposition depending of position ? for instance for fillet weld I run the 3.2 6013 at 110 15 but for vertical up 104 seem to work (with7018 I use higher amps)
for fillet weld do I need more amps (flat angle) than for flat ? Descending I did only try a little , amps at 125
I noticed that I feel more at ease with a strong arc, not feeling the need to shorten it to the max, generally speaking.
But some pretend it is best to use the minimal amps allowing the stick not to stick, so I dont know which direction to work (may be it depends of the rod, too)
Regards
Regards
