just thought I would update where I am at now.
have piped it up as pics show, but it seems like the pilot valve is not doing its job as it is leaking air straight no pressure build up.
so should this be wound right in to compress the spring so it holds pressure.
what I don't get is why is the air feed to to the filter separator so small bore, when 22mm has been used from pump head to res.
not sure why photos are upside down even flipped the as they showed upside and they appeared upside down.
Loosen lock screw and turn adjusting screw clockwise to increase pressure.
