The ATS ones I use are around £60 https://www.atsdiamondtools.co.uk/product/cut-n-grind-vacuum-brazed-diamond-wheel/
Thanks i'll order one of thoseThe ATS ones I use are around £50. https://www.atsdiamondtools.co.uk/product/cut-n-grind-vacuum-brazed-diamond-wheel/
No I haven;t seen that done.Have you tried 7888T with TIG? Around 95A, keep a long arc, just use it as a heat source to melt the alloy.
It is (was?) available in both but the spherical was limited diameters. Can't remember which off the top of my head, I think 6.0mm was one.Is 7888 crushed Wc or Spherical?
My challenge this week - repurposing of a decanter scroll, currently prepping the barrel surface. I removed the vanes before Christmas, new flights in, should be all done by end of next week, all going to plan. The flights will have 30mm x 1.5mm Wc coating by Superjet on leading faces, tips will be done with 5mm 7888T wire rope.
View attachment 432144 View attachment 432145
Hello! I just got one of these and would very much appreciate the zip file. Thank you!Some people here may know I am a bit of a Castolin enthusiast! I now have I think four of their systems.
There is a real lack of information out there. Especially for some of the older powders and systems, so I've been gathering up everything I can find.
Here is some literature I picked up recently - maybe it will help someone out.
If someone was good with image editing I imagine these PDF's could be tidied up a lot. I just used my £40 printer/scanner so quality isnt the best.
I'VE GOT THE PDFS IN A ZIP IF ANYONE WANTS THEM
View attachment 323533 View attachment 323534 View attachment 323535
Hi guys, by digging through our archives, we found this jewel, a very detailed manual of Rototec 800.I don't have a manual for the rototec. I have attached all the product literature I have in this thread.
The only manual i've ever seen was the one recently seen in Cutting Edge Engineering's youtube video.
