Wendelspanswick
Part of your problem is you are welding into an acute V so your struggling to keep the arc centred, you could make it easier for yourself by grinding back the lip so the V is not so deep.
I've got the Parweld (think that's the cheapest one they do?) and I'm well chuffed with it, I've played around with an old buzzbox a while back without any very good results and I'm not sure whether it's to do with learning mig welding or the welder or what but I was able to put down fairly respectable beads straight out of the box, also got a box of the siftrode 6013s from them at the same time which seem to get an okay rating and seem fine with my limited experience.OK.......
I presume weldquip on here is a site sponsor? Would their say cheapest arc inverter be better than anything on eBay? Cheers.
if u cant weld with them u never will weldIn terms of rods - Fincord Ms are some of the best (ebay linky)
Also decent are SIFTrodes and ESAB 46.30s
Dammit!!!!!!!!!if u cant weld with them u never will weld![]()
Not enough amps and not maintaining a tight arc. You have to establish the weld pool and then control the weld pool. Cheap rods often need the current to be spot on. Better rods are usually more forgiving.
Can you put down nice even beads on the flat on a piece of thick steel consistently? If you can, fairy nuf. If you can't, you'll not succeed with a weld like this which is much harder.
As for returning the welder, I'm with mrfuzzy. I've had some slight dealings with customer returns and usually a company finds it easier to take an item back and not argue, even though there's no prospect of reselling it and even though the item's shown signs of deliberate damage. Say it's got an intermittent fault. They're unlikely to know how to test it, leave alone do that.
None of these welds pass muster, it could be user error or plant even rods though. All the advice in the world wont help until we start the process of illumination (basic fault finding). A good welder could illuminate or prove "user error" its here I suggest you start. It could even be the three conspiring
Are you going to shine a bright light on it to illuminate the problem, or did you want to ELIMINATE it![]()
Quite possible, as transformer welders overheat the welds start going bad
Also transformer types are sensitive to volt drop and extension cords exacerbate the issue..
(inverters tend to work more consistently even on extension cords)
another question pardon me if it's been said before but what mask are you using
is it a decent auto one or not
The cr@ppy hand held thing that came with the welder.
Barely usable and quite delicate. Also fixed shade.
You'd notice a big difference with an auto-dark helmet. You can see what you are doing to strike the arc, less chance of being flashed and you have a spare hand, so either two hands on the tongs and hence steadier, or a hand on the work to steady yourself. Not having to manipulate a hand held mask is also one less thing to think about when you've already got enough.
A lot of people on here have had good results with the £25 to £30 autodark helmets off ebay. I'm sure you can find the threads with a search.
