carl0s
- Kelsall
One of the guys from another forum that I go on, did a bit of welding on his wheels. What do you think? I was quite impressed!
I realise this is quite different to crack repair.
There are a couple of youtube videos near the end.
Kevin Doe on norotors.com said:So next step was to widen my wheels. I needed to make a fixture to hold the wheel in the lathe while it was being cut. So I designed and built this little guy. Its two pieces, pressed together, then welded, then machined after welding to ensure concentricity even if it warped from the heat.
Finished up my fixture to mount a wheel on the lathe. Just need to get some quality bolts to thread through as wheel studs and it will be complete and ready for use.
I talked to a materials engineer where I work, and a weld engineer as well about welding these wheels. I was able to determine the casting alloy and go the right filler rod, and right material for the add in strip. I ended up using a 6061T6 strip, adn 4043 filler. Pretty standard. I also purchased a junk Enkei wheel that was curbed for cheap to practice on.
I just cut my practice wheel. Went pretty well. Cut an overall of 1/4" of material away. I'm gonna add a 1" strip here soon, as soon as I get it rolled up. The thickness is 1/8".
Got the strip cut to length and rolled up.
Enough of that foolishness.....
I finished up my practice wheel today. Got the strip tacked on with a super high tech jig. Then put the other half on using a framing square on a flat cast iron surface and feeler gauges.
And the pics...
Method to hold the strip centered up on the wheel as I tack it into place.
Both sides of strip tacked into place, ready to fully weld. (I double checked alignment again at this point).
Fully welded on the inside and outside.
Weld consistency closeup.
Thanks guys!
I welded my good wheels. I measured runout before and after welding. I also mounted a race tire on one and balanced it out. It balanced out to 3 lbs of road force and 1/2 oz. Perfecto.
Here is my backpurge setup for welding the outside of the wheel.
Here is some welding videos I took with my camera. Those of you interested in the welder settings they were as follows: Dynasty 200DX. 3/32" ceriated tungsten. #12 cup, 125A, 80 balance, 150 Hz freq, 4043 filler, 1/8" diameter filler, A356 to 6061-T6 both 1/8" thick.
Welding Wheels.AVI
Welding wheels closeup.AVI
No real finished welded pictures yet. I forgot to take pics before i mounted the tire and put it on the car. Here are some pics on the car. It won't tuck the tires in the quarters, I need to do some more fender rolling. Its close so I don't think I'll have any issue making it work.
I'll call this "hellafunctional" just to spite all the hellaflush dweebs.
Here are some pics of the good wheel welded up, outside only for this one.
Closeup of the beads
And full penetrated, back purged inside. Probably a bit too much penetration, but it doesn't matter. I'm going to be running a bead on the inside as well.
Thanks!.
