Just a little compared to the original counter top.With a bowed sheet (how much btw?)
It does make sense. Should have left it alone. Put the plate back on and its exactly the same as with the other worktopOh, just to clarify...
The orientation of bow would depend on where the main support is - if it's supported around the edges I would put it like an arch so it's high in the middle.
Basically, I'd ensure the unsupported sections are highest.
Still don't know if that makes sense![]()
. Absolutely gutted, what a waste of money
.With the plate off the wood it has the dip.Is that dip measured in the steel plate?
Clamping made no difference.Try some clamps around the edges - that'll show whether edge fixing will help.
Or, a couple more crossmembers.
The mdf is flat once screwed down but there is a 1mm bow in the middle when i put the plate on. Maybe it needs crossmembers like pdg suggested?I'd just put the plate over the MDF, its weight will flatten it in a short time.
May as well give a go then.Probably.
Probably.
In all honesty MDF isn't a great material when it comes to self supporting, let alone supporting other stuff too.
I've built speaker cabinets from 18mm MDF (with a longest side of about 450mm) that visibly flex when driven hard and needed internal webbing for support.
Had I been taking notice earlier in the thread I would've suggested ply instead, 18mm ply is stiffer than 30mm MDF...
