Its hard to see battery tech advancing enough.hydrogen is a lot less efficient than electric charging.... use electric to split hydrogen, compress and cool to -253'C to liquify it, transport it to petrol (or whatever) stations etc. etc. etc.
might be worth it in Australia where they can drive really long distance through the middle of nowhere where it's too far to go on a single charge and there's no where to stop and charge etc. ?
batteries are getting better pretty quickly, I think (just what I think) most of the problems everyone is complaining about will be negated once battery tech advances enough, higher capacities, different materials etc. etc.
And there was me thinking the wider the tyre the more rubber hence the more friction there was..................
It is pretty obvious that a 255 tyre will have more grip than a 225 tyre of the same compound?
Farmers have balloon tyres to spread the load over a greater surface area to prevent sinking & getting stuck - not for improved grip per se.I am sure it is not as simple as that, farmers fit wides tyres for low ground pressure, so I reckon the wider the tyre the less grip per square inch you have?
The engine that's running on hydrogen............
Possibly. What it won't do is generate enough hydrogen to power itself down the road as it takes more energy to split the water that is gained by burning it...That's just what they want you to believe, any basic petrol engine will run on hydrogen
				 www.power-technology.com
				You may want to brush up on your geography...If anyone wants proof the World has gone mad there is a scheme to lay the World's 3 longest undersea cables from Morocco to Britain. They will build a giant solar farm there.
Ovo are backing it
It will help Britain become Carbon Neutral they say.
Wouldn't it be better for the planet to run it to Nigeria instead? Far closer and cheaper with far less losses.
I despair I really do at this insanity.
Never mind it's only 16 Billion. Just whack up our bills a lot more!
Morocco-UK Power Project, Morocco and UK
The Morocco-UK power project is an integrated power generation, storage and transmission project proposed to be developed by Xlinks.www.power-technology.com
Why mad? It's always sunny in Morocco so a few square miles would produce huge amounts of power. Whack the voltage up and losses would be minimal, and you have power which is going to come online every single day on a predictable timetable. What would running it to Nigeria achieve? Apart from providing them with the same, but then, they have lots of sun too so they could do it themselves...If anyone wants proof the World has gone mad there is a scheme to lay the World's 3 longest undersea cables from Morocco to Britain. They will build a giant solar farm there.
Ovo are backing it
