MattF
- South Yorkshire
So what do you do with one then, all I can think of is press bearings in
Press, punch, bend etc. It all revolves around the tooling. You could use one as a box pan folder, for example, for punching holes or slots, (a louvre in a panel is one example), pressing things in/out, stamping, flanging etc., etc. If the piece will fit and you can create/buy the tooling required, those are pretty much your only limitations as to its use for anything which can be done by applying pressure.
