CRB
Just wondered if I could get a bit of general guidance regarding tooling namely the bolster shank. Is there a general type of length on the shank? This plate on this ram is stuck in there solid, so I'm drilling through the approximate centre of the shank to try and get a bolt in there to push it out. I'm pretty much drilling blind with regards to how long this shank may be though, so trying to get a rough idea of what an approximate length of the bolster shank may be. Wanting to minimise the possibility of drilling through into the rams bore if it's bottomed out in there.
?Is it the part which looks like a bowler hat you need off the lower end of the ram? I have had a look for a nomenclature of a flypress, but no joy.
Putting it all back together and then using screws to push it off against the machine, would allow you to press from more places than the centre.
I suppose heating or freezing is not an option.
