Hi all!
Does anyone know anything about turning fridge compressors into useful compressors for powering tools from?
I managed to salvage a compressor from an old fridge and got it to run all right now (after spraying freon and nasty fluorescent blue oil all over myself). Does anyone know what sort of pressure they can pump to, what sort and where to find a reservoir tank, if they would be suitable anyway, if they need any maintenance, or any information at all really
Thanks in advance!
........ the other problem that you said that youve had is oil emulsifying you might have a comp that was on an old cfc comp mixed with a comp that had the ester oil in. the two oils dont mix and create a foam like gunge.
 So I can test the pressure, which I will do any minute now, and an air tank from a lorry sounds like a great idea! (I have an aversion to buying anything new!) But what are the reeds?....... But what are the reeds?
I'll get back to you as soon as I have tested the pressure
Thanks all!
Keep your eye out for the commercial type refrigerators more cc`s and just as quiet less mtrs to get ur cfm then !
