I'm on the verge too only the worry for me is the fragile roof tiles and how the panels actually mount up there.So about 3k without batteries?
You are not going G98 then? or does the actual output still comply?
(watching with interest as i think i might do this)
I think so as they are holiday cottages and need to look the part too. One set integrated the other clagged on with 7nistrut would irritate me every time I looked at it.Integrated panels, supposedly the best way - hardly seen though. Is it worth the hassle?
Here's a good explanation of dual mppt PV inputs.The Sofar HYD inverter has two PV inputs. I'm assuming I could start with only using a single input?
Also, as long as I have enough panels to meet the minimum voltage, the inverter will do it's thing?
www.solarpowerworldonline.com
I based my system on roof size and getting the most panel area in a limited space.Given today's announcement, I'm reconsidering solar, but I'm struggling to find a definitive answer, so if you don't mind, I'm going to hijack this thread for a few questions.
And how do you decide on solar panels?
I've got as far as Mono are more efficient/more expensive, with poly being less efficient/less expensive, but I'm guessing the rest is just down to picking whatever manufacturer/output/look/warranty/price you think is best?
At the moment, I was looking at the HYD-3600ES with these panels from TradeSparky - https://www.tradesparky.com/solarsp...a-solar-jam60s20-380mr-380w-silver-frame-mono
380W with a voltage of ~34V
6 x 380W would give just under the max single PV power input, but only about 204V output (MPPT operating voltage is rated 90-580V, with max power being 180-550V)
I'm assuming that if I was to add more panels to the string, the inverter will only use the max 2400W, with any extra energy unused, but have the bonus of more output on darker days?
InterestingI've only skimmed the thread so not sure if you've got it sorted, if you're still thinking about adjusting the angle I've got dozens of linear actuators that might be ideal for automating it, I'd be happy to send you some. You could use a MEMS gyro to monitor the angle and feed it into your data collection system to see how the panel angle correlates to the power output too.
