Hattori-hanzo
- Uk
With the black paint now dry I could start applying the lacquer.
I sprayed 3 coats of lacquer onto the box leaving 10 minutes between coats, no need to rub down this time.
Once the lacquer was dry I started to cut it back with wet and dry sand paper.
I sanded from 1200 to 2500 grit.
With the entire box sanded to 2500 grit I could start to polish it.
I'm using Farecla g10 finishing compound and a medium sponge buffing pad to bring back the initial shine.
Once I was happy with that stage I used super resin polish and a fine sponge pad to get a gloss finish.
Lastly I applied a coat of Dodo juice for a little extra shine and the sweet smell of Carnauba wax
With the paint work done I fitted the brass handle and lever catch to the front of the box.
I also added some Velcro strips to secure the plane in place when in the box.
Finally I cut and fitted foam to the inside of the box just for a little added protection.
Other than adding some rubber feet the box was complete.
