Hattori-hanzo
- Uk
Thanks Craig
you cant re sharpen them its a throw away item. as said its ruined with running to fastThanks for your comment Keith
Does any one know any thing about metal band saw blades?
I ordered an m42 blade with 14tpi, vari pitch as I read this was best for cutting 6mm steel.
I got the blade today and put it into our wood cutting band saw but the blade won't cut the steel.
I ran the blade for 10 minutes before using and sprayed it with lube, tension seemed good too but It just won't cut.
I did a bit of research when I got home to find out that the cutting speed may have been way to high.
It's not the fastest running band saw but like I say it's a wood cutting saw with no speed adjustment.
I'm guessing I've ruined the blade by running it to fast as the blade won't even cut brass now?
Looks like I'll have to go back to using the hacksaw, bit disappointed as I've got a load of steel to cut away on the current plane, was hoping the band saw would save a lot of work.
Also Can M42 blades be sharpened? or are they a one use item?
Not that it would be much good unless I could find a way to reduce the band saw speed.
You can get a simple plug in variable speed contoller / regulator to run your band saw motor slower . You might have to sort the plug lead out to get it to work on a UK socket & keep a length of the moulded plug lead to make an adaptor for your band saw feed cable.Ah ******, oh well live and learn. Looks like I'll be doing it the hard way
