But... If you eat that little thing raw, it will remind you of how carrots used to taste when you were a lad! Hard to get a sweet and 'carotty' carrot these days. If they sold those thinned out carrots in a restaurant they would probably cost the same as white truffles!
They'll be fine, it'll just add to the flavour and give a little more bite.Will the berries be safe enough I wonder to make some "Dead Fox" vodka?
You need to manure in Autumn after the crops are harvested dig it in well & over winter it will leach out the main easily had nutrients and then the rest of thbe matter slowly decays at different rates over th nerxt seven years . Do a three or five year crop rotation cycle ( the five year cycle of manuring is perhaps the b est for it allows five different crop types in their own beds , perhaps do a soil acid test with a cheap test kit , lime as needed to keep the high acids down .My veg patch soil "smells".
That's the only way I can put it. Not a rich, earthy smell but a manure 'ish, something has died in it type smell. Disturb it and it proper chucks up. It's very light in colour too:
There was a dead fox a few months back that leached a bit and I did rake in a couple of bags of manure that had been sat in plastic bags for a couple of years but hadn't rotted down.
Is it that it needs turning over or something adding?
I've a near flat, tiled roof needs clearing of moss. I was considering spreading that (the moss) over it now.
Usually if you can grow nettles in the veg bed ground you will be able to grow most UK veg with ease .
You can fan train your brambles as they don't grow on this years wood , so all new growth is tied to wires in a fan shape and the old wood is done on the opposite side of the fan , then after harvesting cut the old wood down and shred it , use as mulch or burn it for potash
I shoved a bucket of roof moss in each of four of my 4x4 square foot beds they seem to be in need of getting a lot of air in
Rotting plant matter can also smell awful depending on the bacteria present. Rotting birch will often smell of vomit.
The pots I had oak saplings in were also smelling foul, I believe it was from over watering/root rot and attempting to use coffee grounds to feed them, coffee grounds are bad for roots..
