My neighbours house is quite close to my garage, although i'll be taking precautions and rigging up a extraction system through the garage loft and venting paint fumes out the soffit away from there house, i want to know if the paints safe enough to use at home, otherwise back to celly..
Thanks
Gaz
Jawel say that the mix is 2:1 plus 15%. This is the mix I have used today and it goes on nicely with a 1.3 LVLP gun at 20lbs. Took a while to go off, longer than the aerosol primer I used underneath. I managed to put fingerprints in the paint nearly an hour later, but another area of the car went on and hardened as expected. Leaving it until tomorrow to see if it hardens enough to flat and repaint. Left the paint in the gun, so trust it will not coagulate overnight!
The reason for me using the unibinder is to experiment with blending. I am hoping that it will be easier to compound into the rest of the panel, like cellulose. It is also saving me from having to,get dressed up and get the air fed out.
I have central heating, yes. Temp probably 16 degrees or so. I was surprised at how little smell there was. The aerosol primer could be smelled all the way through the building, but strangely, almost nothing from the non iso. No idea what standard 2k mix smells like of course, maybe that is the same? Not about to find out. ;-)
