thank you for your simple and ingenious solutions, such as those used by the ancient Egyptians to erect the majestic pyramids, they did not have cranes or caterpillars, they did not have forklifts or telescopic telehandlers, but ingenuity sweat elbow grease and good muscles, thanks again fori tupoi advice and suggestions, always precious.
but i wouldnt advise it fastened to your scaffolding if it fails you could lose your scaffolding and any person on top of it
best off on its own gin pole and scaffolding used as climbing and tightening of bolts
the use of the block and tackle is really to make it easier the problem is length or rope needed so 40ft would be x7
before it hits the winch the one advantage dont need as many men to lift gear and it pulls up slow and safe but you need a longer wider reel to roll the wire onto or thicker reel so the wire can spool onto it
Does anyone have pictures / drawings of anchor deck capstans for merchant ships from around 1860? The plans are lacking in any real detail. This is what I have to work with at present: Thanks, Grant.
thanks for the right suggestions, I honestly had thought of modifying the mobile scaffolding with wheels to reinforce it and create a sturdy lifting point, on which to hang the hoists, but I believe that if I do not ballast it with bricks or with barrels of water it will safely tip over due to the imbalance during the lifting phase, the only solution would be to find a pole, create a base and apply a hoist to it. anyway thanks again, you are very ingenious simple but functional proposals, thanks sorry if I disturbed you. thank you if you are very valuable, kind and helpful.
thanks for the valuable suggestions I own the hoists, now the only one is to create the lifting structure with recycled material, thanks again, sorry if I took advantage of your ingenuity, your experience and your patience, thanks and sorry again.
This article discusses how to suspend circus equipment from box truss. Update: We have a video [https://youtu.be/-nUZqLCx9W4] we created on the topic For circus rigging, we use equipment from many different sources – most commonly the lifting industry, rope access, scaffolding, and sailing...
