My guess is about enough to light the odd cigaretteI want to know how much biogas I can make from my half acre of greenery and free cow manure.
Didn't you have an ingenius method of removing the nails?As you know I burn scrap pallet wood. The thicker stuff from 2 way pallets thst nobody wants. Incredibly clean burning. Only a tiny bit of smoke on start. No smells outside the house not that I have any neighbours. I even save all the nails for scrap![]()
No. My mate who strips the pallets runs them through a horizontal band saw. It cuts the nails in the gap between the block or bearers and the planks.Didn't you have an ingenius method of removing the nails?![]()
because im cutting it up with a circular sawNo. My mate who strips the pallets runs them through a horizontal band saw. It cuts the nails in the gap between the block or bearers and the planks.
I just chuck the wood in the fire. Use a magnet to get rid of all the nails.
Her felling technique needs some improvement.See the log lady stacks your too!
High hopes of that.Thats normally what is done to kill a tree.
Or is it a rubber tree ?
Are the little fans that sit ontop of a log burner any good?
Definitely helps move the air about I've found, if it makes a massive difference I doubt it but every little helpsAre the little fans that sit ontop of a log burner any good?
Barely..Are the little fans that sit ontop of a log burner any good?
