Dieselman 63
Forklift Certified
- Wellington, New Zealand
Just been reading the thread. Some good stuff on here.
I had no use for speedbrace either @8ob till I saw this. Guy Martins wheelman uses one. You have to go on the tool van and take it like a man as strap on own the patent but it’s damn handy for wheels if you don’t have a battery gun.
View attachment 311092View attachment 311093
Breaker / brace combo
as for size, 99.9% of stuff on 3.5t it’s easier with 3/8 or even 1/4 drive. Even a lot of stuff I do on big marine and HGV I don’t get the 1/2 set out.
Big nuts on big stuff, yeah it needs a bit of love to shift it but you’d be surprised how much you actually use <19 or 20mm sockets on big things. I’ve up to 22mm in 3/8 and usually it’s enough. On big machines it’s more an access issue nowadays anyway. If I need big sizes I tend to jump to the 3/4 set. I rarely use the 1/2 as the other two overlap. Maybe 24, 27 and 32 in 1/2 sometimes but that’s about it.That’s a cool tool. I do not own a gun, so it’s always the speed brace for me. Plugs on a Mitsi GDI engine too, lost in the deep caverns they are… brace is the perfect depth without faffing with extensions.
Surprised about the marine not needing larger sizes. When I was working on wheel loaders that had been working in sand the bolts on the cleaner bars were nigh on rusted to the nuts. 3/4 with a 4ft breaker bar struggled, it’s the only time I’ve ever used 1” sockets on a rattle gun, some we even had to use the gas axe on!
I have, seen that brace in the catalogue, for years. Could never figure out a use for it. It makes perfect sense. Just never thought of using a brace for, loosening anything other than finger tight bolts and nuts.Just been reading the thread. Some good stuff on here.
edit - P/N: SN4B for those interested
Probable next purchaseI was always taught the same People don’t seem to be now, or they are lazy. I get a decent amount of crosssed stuff to be machines out. All this battery gear being so available I suppose.
It’s a handy tool especially on bikes. I leave it in the truck as you know when you get a flat you won’t have a battery gun with you and it’s tons better than that poxy wheel brace they give you!
Ive never got on with them on engines to be honest. Never enough room. I do like to use a T spinner though. Handy for running things on and off once they’re started.
Yes. I’m not sure if they do different drive onesLiking the speed brace / breaker bar combo. Assume its 1/2"?
