DAPPH
as dyslexik as I'm daft
I did back in 2008 when refurbishing the bungalow on our first £158 full swap over to 24 x 3-watt LED gu10's & 18 x 2-watt corn bulb wall light LED's (there are still 9 x 20-watt G9 halogen lamps in the almost flush three hallway light units, but as they are rarely used it's not worth the cost to change them.I started writing the install date on my led lamps (started with them long life compact florescents) when I put them in as I've had a few go kapoot in the first year.
Since I did that they haven't been going pop so quickly , is this smart lamps maybe ?
Stu
Most in the kitchen & lounge LED's lost noticeable luminescence after 10 years (save for those that were switched on when we got struck by lightening, which fried all things switched on), so I bunged in a complete new set in the areas. This time however the cost was about £1.60 per GU10 lamp .
Of those early very expensive LEDs ( Phillips branded ) that survived the lightning strike, all the bedroom & bathroom LEDs ( qty 16 ) are still giving out good light.
Compared to the 60 watt incandescent bulbs or the 50 watt halogen ones in the same areas it's a no brainer to have the LED's , for the 50 watt halogens were popping almost weekly throughout the home (we used to buy the replacements at a about £ 3 each in boxes of 10 . & the other before that earlier 60 watt incandescent in the lounge or kitchen died around every six months or very close to that mainly I suspect to dirty mains surges /spikes as we are at the end of a long complex branch line.
Since we have had a major power line refurbishment program in the locality, we haven't had many LED's failings save for one in a cluster of six GU9 2-watt corn bulbs on the lounge ceiling, for some reason this bulb seriously dims down to being out over a week or so about every six months, maybe it's down to a back emf spike when the cluster is switched of and this leg perhaps being a slight lower resistance in the wiring inside the light cluster gets the greater belt.
When setting up the wiring for the lights because of eddy currents & back emf's in ht lighting wirings I took great care to measure all wiring from the roses to the light units in each room and make them the same length then spiral wrapped any excess cable round different roof trusses, so I got a balanced resistance to each light fitting unit.
