Hood
- Carnoustie, Scotland
Thats a nice box Hood, its going way beyond budget though i think, add on a torch and work lead as they don't come with, and i'm nearly at £3k !
EWM Picomig 180 Puls I see for £2100 or so, you reckon a torch and earth lead would cost £900 ? Prices on line are usually negotiable, maybe a lot, maybe very little and occasionally not at all but you never know until you try.
You mentioned you wanted to do Alu so that is why I suggested the EWM Puls as in reality, or at least my reality, welding Alu with a normal Mig is for 3mm upwards, with pulse you can go way down, so depends what thickness of Alu you are talking about. As I said previously people do weld thin Alu with standard Mig but they are not in spray transfer and things get messy in the surroundings and one thing I have learned, Alu spatter does not bounce off clothes and skin like steel spatter does
I have never used pulse on steel or stainless yet as I don't use Mig for it but seemingly it is nice, time will tell as I intend to try out some stainless seeing as I was given a few rolls of flux core, just need to invest in some gas.
Edit
just seen a Picomig 180 Puls advertised with torch, work lead and reg for £2220 but as said most places have a bit of come and go on prices, sometimes very little, sometimes a bit more.
So i don't 'think' its a WF issue, unless it only shows when under arc power.
Both tacks spattered a bit, then when starting each of the 4 welds i got a couple of seconds of spattery arcing before the weld started proper - result = spending 25minutes with a grinder and a file getting all the junk off the job and trying to cover up the mess. Luckily its powder-coated so will look ok in the end.
