hotponyshoes
- Somerset. Uk
The a/c pumps work but output is low. Fine for emergency use but to do anything useful you really need an air tank for storage.
For the space the tank takes up you may as well just run a small electric compressor and an inverter. Or just carry a engine driven compressor around.
Or one of the cordless options if you already have a battery system and can get by with a couple of cfm?
Or you could mount storage tank(s) somewhere out of the way and fill them from the workshop compressor before you leave.
Also, if it's a modern diesel van, leaving the engine tickling over with no load might well give you grief with the egr, dpf, etc. especially if the compressor pulls the revs down. Most raise the rpm a bit when the ac kicks in although if the van was originally available with ac it should be possible to trigger that with a bit of fiddling
