James1979
- Orkney
‘Kin ‘ell!!!I've seen 30bar on a faulty unit.
What do you have on your van, out of interest?
‘Kin ‘ell!!!
Quick look on eblag turns up new units less than £200Have a look at the vw touareg, I had one and that had a hose under the drivers seat you could pull out.
Never really played with it but that ran from the on board air suspension
Correction, had...@sako243 has an ac pump on his defender. I suppose it would depend on air requirements, an ac pump would be ok for pumping up tyres but wouldn't run windy tools.
Bob
There is if it's an L322 - it's a long cylindrical one tucked up under the drivers side (I think). Only a few inches in diameter but most of the length of the car. Probably under a minute or so for the compressor to lift up the vehicle from flat to full off-road height but the bags do run at a reasonable pressure I think. At least will sustain it because of hitting bumps etc.There’s no tank on them as far as I know so that’s promising
I wouldn't consider the output to be low... My setup would out perform my workshop compressor (4.5hp compressor with 250l receiver) and it only had an 18 litre tank with it, and that was with the Land Rover idling.The a/c pumps work but output is low. Fine for emergency use but to do anything useful you really need an air tank for storage.
For the space the tank takes up you may as well just run a small electric compressor and an inverter. Or just carry a engine driven compressor around.
Or one of the cordless options if you already have a battery system and can get by with a couple of cfm?
Or you could mount storage tank(s) somewhere out of the way and fill them from the workshop compressor before you leave.
Also, if it's a modern diesel van, leaving the engine tickling over with no load might well give you grief with the egr, dpf, etc. especially if the compressor pulls the revs down. Most raise the rpm a bit when the ac kicks in although if the van was originally available with ac it should be possible to trigger that with a bit of fiddling
I've seen people making tubular bumpers as air tanks.I you might not like thisWhen I built a LR90 I wanted on board Air. I was going to use a RangeRover Air con unit. But then... it was suggested to use a Pub CO2 bottle. Plenty of air(Nitrogen) wont flat your battery takes up little space, and is instant.
Sorted!
most truck compressors are gear driven off the timing gears and take an oil feed. the only belt drive i can remember were gardner ones.Sorry, not read all three pages, a 7.5 ton lorry air brakes compressor, and tanks, jumps to mind.
I've a Dahl one off a Detroit Diesel, somewhere.most truck compressors are gear driven off the timing gears and take an oil feed. the only belt drive i can remember were gardner ones.
that would be interesting in a crash!!I've seen people making tubular bumpers as air tanks.
Pop, pssst.that would be interesting in a crash!!
I know someone who made their roll cage on a Jimney an air tank for lockers.I've seen people making tubular bumpers as air tanks.
Basically, yeah. You’re right.Two realistic options, if you look at what the tyre fitters/plant repair guys use.
PTO/Belt Driven Compressor and underfloor tank.
Petrol/Diesel Piston Compressor & Receiver
