Because the edges of the board need to hit joists...But why remove laths?
If boards are going to be screwed to joists?
That's the bit I don't understand...
LolOk.
I get it now.
STILL don't want to take down the laths, tho.
3x2 CLS framework to screw boards to?
just do it right and don't cut corners u will regret it if u do.been there done it and got the tee-shirt
I predict a LOT more muck in my future.
There's at least 9in in the loft, if not more.Erm you are going to be putting up some insulation i take it?
That's what GF says...just do it right and don't cut corners u will regret it if u do.been there done it and got the tee-shirt
Yephes plastering it himself after hes boarded it arnt you bigegg
got a decent float run in have u ?what make. I use marshaltown and tyzac
I like "Ripon carboot sale 50p"got a decent float run in have u ?what make. I use marshaltown and tyzac
for whatI'm at a point where I'm considering 0.8mm galvanized plate with 40mm X 3mm laid over
Panelling the ceiling.for what
Probably.
Never tried
I did an alcove in my old house - was easier than I was ledto believe.
I've done a fair amount of rendering .
