RaceDiagnostics
- Broughty Ferry
There is an oil pressure gauge, oil filter was pre filled full, 8l of oil in in total, all 8 spark plugs out. How do you prime the pump before fitting?
For the gear motorbike ones I have done fill with oil / lubriplate in the gears when rebuilding so the gears seal better, pick up easier.How do you prime the pump before fitting?
+1 for the Vaseline on the Rovers, though I did need to explain to Mrs. Zx9 why I had put 500g of Vaseline on her shopping list.The V8 rovers were always had there gears filled with Vaseline (petroleum jelly) and it encourage the pump to pick up the oil. But another trick was too over fill the sump by a couple of pints to prime the pump by turning it over until pressure was seen on the gauge
Looks like you can fill from the oil filter supply pump from cooler given that it has no none return valve from the cooler to the pumpAhh, tomorrow I will also fill the oil cooler, that should also prime the pump.
