Resin with plastic top hat cages
I'm going to be using resin for a handrail in brick, im using m10 threaded bar would a 12mm hole be enough, could I get away with smaller?
That sounds like a right royal pain in the behind?Well I had to do some more resin holes today to put up a basket ball hoop. What a job ! But that’s another story. Anyway 6 holes in total at M12 so I had everything prepared - studs cut, holes drilled and cleaned out etc and duly squirted the resin into each hole.... yup by the time I put the gun down and got to pushing the first stud in it had already started to go hard. Must be extremely temperature dependent - it’s pretty warm here at the moment. Had to re drill 2 of them but managed to get the others in ok. It’s done now (although waiting till the morning for final tightening) but had me cursing on the inside for a while there.
Must be extremely temperature dependent...
Sounds good advice. I checked and it’s about 5 min working time but I thought I was well within that. Anyway it’s stuck on the wall now - a couple might need redoing to satisfy my perfectionism but it’s not going anywhere for now.Yes. And the better brands of resin (Hilti, Spit, etc.) will have a graph on the instruction sheet that gives cure time vs. temperature.
You can slow it down by leaving it in the fridge. In the winter, you can speed it up by leaving it a heated office rather than in a cold, outside toolbox.
Can’t see why not. I used rawl bolts for everything until this resin was recommended on here and I would t go back now. It’s not as messy as you’d think and it seems pretty fool proof.Not used resin before always rawlbolted into concrete but intrigued. Would it be suitable for anchoring a 2 post lift down onto a 6" concrete slab?
I stuck a five bay shed made from heavy duty 5 mtr tall industrial racking to the 18 inch outer thickness of the floor pad of a 20 x 40 foot shed , putting four holes & resin anchors in each upright .Can’t see why not. I used rawl bolts for everything until this resin was recommended on here and I would t go back now. It’s not as messy as you’d think and it seems pretty fool proof.
