Just to clarify, the trip that is causing the problem is an overload trip, not a thermal trip.
Now it's either faulty and therefore tripping prematurely or there is an overload caused by another fault in the motor or related component.
My fault finding philosophy is to eliminate the easiest and most obvious potential causes first, before getting in to more detailed examination.
The next thing I would do is bypass that overload trip and see how the motor behaves then. If it shows any sign of struggle to start, even under a cold, pressure start, then I would investigate the start and run current and the caps. But my bet is that the trip is kicking out prematurely.
Testing caps without a test rig that can test under working voltage or near to it is a waste of time. A megger may detect leakage at high voltage but it can't test the caps value. However, if either is leaking at high voltage they are on the way out anyway.
