It isn't pictured, whether it has the gas hose or not I am not sure. Reg probably not but not something I will worry about as I need Nevoc ones anyway.Is it just me or does it look like the Sherman doesn't come with a regulator and pipe to the machine??
I was just shy of £500, maybe the paypal exchange rate or something, maybe should have done with credit card.
Here is what I can get it on ebay for, about £38 cheaper.
You will on Monday as I have asked one of the Jasic engineers tonight and he getting back to me on Monday
Really hoping there is literally no difference
No hose or regulator, comes with the female rectus connector with hose tail to fit the back of the machine thoughIs it just me or does it look like the Sherman doesn't come with a regulator and pipe to the machine??
You will need pure Argon, a regulator and likely tungstens, collets and wire.Hi guys, new to the forum and pretty new to welding, I have been wanting to try Tig for a long time but have always seen it as to expensive, believe it or not I had the Jasic in my cart and thought I would do a bit more research and stumbled apron this post! I pretty much thought what the heck and went ahead and purchased the Sherman! I would like to know however, what would I need to buy now to have everything I need to get started when this arrives? I will probably just start off welding steel for now and try Ali at a later date! Sorry for the newb questions!
The best 13A plugs are Masterplug, Permaplug, or the MK 655 plug.you will also need a hefty uk plug, or a 2 pin adapter. Comes with a molded EU plug.
I am fine for testing purposes as I can just unclip the adapter that came with the GYS stick welder.The best 13A plugs are Masterplug, Permaplug, or the MK 655 plug.
Well one thing is for sure, I don't have themOr if the mrs has ghd hair straighteners
I will use an adapter to check it out and if I think it is better than the Stealth then I will likely replace the power lead to keep the original intact if I need a warranty repair.I use an adapter so I dont void the warranty
One think thats been bugging me over the weekend...my Kemppi (mig) claims to weld Aluminium...is that possible with a mig? ...
