Memmeddu
- Italia Sardegna
They usually have just a brass disc with a rubber gasket.The ball bearing from the wall? Maybe fortuitous you weren’t shot by it.
The non return valve on my compressor stopped working and when I stripped it the spring was broken. I stretched what was left of the spring and reassembled it just to get going again. It's been like it for a few months now and still working. No ball bearing in it just a rubber disc in the end of the spring. The pressure release safety valve is different.just had the end cap of my compressor non return valve blow out.. i have found the spring and the remains of the cap... guess i am missing a ball bearing
made me jump
no pics yet as i will have to dig it out first
Well the two valves arrived.I found a tyre valve cap on tge bench a few of days ago. Eventually it dawned on me, in the wee small hours, that it was from my space-saver wheel that I'd pumped up for the first time in 8 years
Out to the car to replace it, only to find a soft tyre and this...
The damned thing has failed. It's a good job that I hadn't needed to use it ( in fact it's never been fitted, and the car is 2005).
Down to the local tyre place only to find that it's smaller than for a standard rim, and they don't carry any in stock
Easy to buy if I was in the US, or wanted 10 from Europe, but seemingly hens' teeth in the UK.
I eventually found a couple on eBay - £17.11
After sitting for 18 months, my ultrasonic cleaner doesn't sound too healthy
It was full.Sounds like Flash Gordon's in town!
Did you have any fluid in it?
Nope. It's in exactly the same position as the last time it was run.Sounds like Flash Gordon's in town!
