Mismatched screws.....tut, tutReplaced the Axminster switch,they replaced it under guarantee,it still has a faint vibration when thru the button as you press it.View attachment 345364
Yep, it offended my OCD when I saw that.
Just gone in the workshop and the switch is faintly humming,working fine though,any ideas?Replaced the Axminster switch,they replaced it under guarantee,it still has a faint vibration when thru the button as you press it.View attachment 345364
The switch has a coil in it that is energised when you push start. If you push stop OR the power goes off, it drops out so when the power comes back it needs starting again.Just gone in the workshop and the switch is faintly humming,working fine though,any ideas?
Oh and the mismatch of screws......it’s so far down the list of jobs,that it’s now buried
They're rubbish. I've a D bit grinder and a small horizontal band saw with those NVR switches. Both buzz.Replaced the Axminster switch,they replaced it under guarantee,it still has a faint vibration when thru the button as you press it.View attachment 345364
the sockets on the p..ss . like a ski slopeMoved the double socket behind the drill press and put all the drill bits and router cutters away:
And repositioned the plastic bin rack and made a storage area for steel stock where the cabinet used to live:
Much more of this and I might actually be able to make stuff
I’d be perfectly happy with a simple on/off switch,but inside there’s 5 wires to connect,wouldn’t know where to start.odd as the previous same one didn’t buzz.
Post a photo of it. I'm sure someone on here will be able to guide you in simplifying the setup.
I never bother with NVR's on my gear. Keeps good practice & common sense on form. Much prefer toggle switches.
Nnnaaaahhhh.....!.......Post a photo of it. I'm sure someone on here will be able to guide you in simplifying the setup.
They were on flexi hose which aren't stretchy hoses unfortunatelyJust use push fit flexies on them taps next time?
A friend who is a plumber told me not to buy unbranded taps. He reckons they make them from the parts scrap bin...when they fail it's impossible to get parts because even the original maker doesn't have a clue.
You're just setting yourself up to being caught out one day.
Presumably you've met my ex-MIL (Rawmarsh) .I'm no stranger to danger.
