JOEPRO
- UK
Today our heating packed in. I thought it was a bit too cold in the house and when I checked on the thermostat it was 9 degrees in our house.
The boiler, a Glow Worm 24hxi did not fire up and the fan was fluctuating.
I thought it could be the pump because that was not running either.
I tried the obligatory normal fix of hitting it softly with a hammer in case it got 'frozen' with limescale, sediment or whatever else that normally lurks in central heating pipes.
First 'fix' was unsuccessful.
My second attempted fix involved checking if there was a voltage output to the pump when I had the heating demand on.
No voltage output to the pump. I didn't want to mess around in there too much, if wires pulled out of their connection points I would have had no clue where they were supposed to go.
Because there was no voltage going to the pump I assumed that the pump was likely good and the problem was either with the control or the boiler itself.
I powered cycled the boiler a couple of times and the boiler then threw a F12 error and a red LED light.
An F12 error on Glow Worm boiler = Connection fault between main printed circuit board (PCB) and display PCB.
Off with the boiler's cover!
I unplugged the connections and replugged them to see if it would cure the problem.
No luck.
A few years ago, after we had our smart electricity meter installed, the boiler did not want to come back on after the power was turned back on.
The display was dead and I heard a ticking noise.
I came across a very helpful post on a forum that said:
"Dead. No display and fuse is in tact. A faint ticking noise can be heard and may eventually power up after a while:
The switch mode power supply (adjacent to the fuse) is not starting up. This is caused by a faulty electrolytic capacitor C805 situated at the bottom of the PCB near to the fuse. This is a 47uF @ 50v.
It may also be worth replacing C813 (100uf @ 25v) on the power supply secondary at the same time. This is situated at the bottom of the PCB to the left of the small transformer.
You may experience the above fault after recycling the power for service or after a power cut."
As it was not winter at that time we didn't need heating and the hot water could be heated via electricity I thought I would try the suggested fix.
I ordered all the required capacitors (a selection box on Amazon Prime) and some 470UF from RS components. The Amazon capacitors arrived the next day (on a weekend) but the RS component capacitors only arrived the following week.
I replaced all the capacitors which had the correct values out of the selection box and the board fired up!
Today I remembered that I did not change all the capacitors the last time (because the RS component ones arrived the following week after I had the board working again) and thought it would be worth pulling the board again.
On closer inspection, I identified a capacitor that looked a little suspect.
The left capacitor looked a little 'bulged'. Worth a try to replace them. Especially as a new board is £226.99 from Screwfix
Refurbished boards can be purchased for much less though.
I have a Chinese multimeter that can measure capacitance (probably not too accurately).
I measured a new 470UF capacitor and got a reading of 530UF. A little bit more than the expected 10% tolerance.
I removed the two old capacitors and then measured their values.
Capacitor 1 = 90UF
Capacitor 2 = 2.4UF
Way off the 470UF value they were supposed to be.
I replaced them with new ones and tried the board in the boiler.
Success!!! Green light and the boiler fired right up!
The Glow Worm is glowing once more!!
I am super chuffed with myself that I dodged the call-out, diagnoses and part costs by not having to get a heating engineer to fix our heating.
Very good diag and repair!
A heating engineer would not have checked all of that and instead throw new parts at it!
