prepman
- Gwynedd UK
Swagelok, Gyrolok etc double ferrules3000psi most compression fittings
This is 3500psi, not that that would make much difference. I can flare so I flare. I haven't priced the compression fittings for a long time, but do remember they were over double the standard JIC's. Anyway I like them (JIC) and got it sorted flaring them so I do it that way3000psi most compression fittings
What sort of kit do you need to flare the pipe?This is 3500psi, not that that would make much difference. I can flare so I flare. I haven't priced the compression fittings for a long time, but do remember they were over double the standard JIC's. Anyway I like them (JIC) and got it sorted flaring them so I do it that way
I have Imperial Eastman, yanke stuff, it works and have had it for years. I have two sets, smaller for up to 5/8" and a bigger for 3/4" up to 11/4". Dr Google will show you what they are, I think, yes just checked they are the roller flares. Hope that helpsWhat sort of kit do you need to flare the pipe?
A " Pipe flaring & nipple forming kit" in whatever size & thickness of pipe work you are working in .What sort of kit do you need to flare the pipe?
Nice !
Its positioned to catch the morning sun. I doubt it's particularly optimal in any way!What sort of angle to the vertical and position of the sun , at what time of day please .... it all helps to know real peoples input on these things .
I suspect having the walls of our suntrap and those of the neighbour who are four feet higher than the bottom of our panels & being of a very light colour has helped reflect a lot of useful warmth & UV to the panels on our SSW roof aspect the roof.
One nearly off the "honey-do" list, a new garden table.
Got some hardwood planks, not sure what they are, not oak anyway, before Christmas, and let them dry for 3 months.
Cut the circle with a jigsaw, and power planed the edges square. Glued the planks together, squeezed together with a sash clamp and clamped flat to the "heavy" until set.
Made the legs out of 2" pipe, I've always liked the look of this design. Simple and I like 3 legs for outdoor surfaces over 4.
Planed and sanded the top and edges.
Gave the top a good soaking in Osmo WR basecoat, hopefully a regular top-up should keep mould/rot away.
Got the bottom side to coat in Osmo, and maybe a 2nd top coat, before delivering to our garden...!
Cheers i measured the angles/width that I wanted in 2d and mitred the pipes. Then marked a mid point. Tacked each pipe loosely in the right point to the top frame, and moved them about with a spirit level on top until they were all in the right place and welded together. One of the legs had a slightly larger gap to fill as it must have been slightly off, but shhh, no one will knowI saw that on the 'gram and meant to ask there; how did you line up the three legs so they all crossed each other correctly - and at the right angle? Lovely work.
I like tables and stools with three legs; you don't have to worry about things wobbling!
They are part of my current art projectStarting your own armaments industry then ?
