redlig
- wiltshire uk
Unfortunately it does not , ( see my post above ) , it only get the flying wasps & some newly hatched ones /@redlig How does that work?
I just killed off a massive nest above my son's bedroom window and that took a whole bottle of that wasp killer power. I only got stung once...
Thanks for tips and tricks much appreciated. I'm only using the steps to rest the tubing . The nest is in the void above the soffit board and really don't want to remove soffit except as a last resort. I'll have a few more goes and then try to fumigate the void with yet another codge up." Raid wasp killer " a full can squirted inside that length of tube by sealing the edges to the can with a cut soft vegs like a potato or a marrow so they get the whole can in the nest is the best way , just sucking out the hatched flying wasps will still leave a a few hundred or more to hatch out and carry on till winter .
Being able to make up the Henry in a plastic dust bin with the inlet air being sucked in throughthe bin wall via a sealed pipe so the outlet air can now be blown along another exit pipe is good , quickly tape an L shaped bit of metal to the side of the can so it is tight down over the spray button to keep it on , drop it in & close the lid quickly then start the Henry it will blow the Raid into the nest and soak the walls with microscopic droplets of it . Check it 24 hrs later ..you may have a massive over wintered nest in the roof void .
Do be careful don't work off a ladder unless very well protected over head , hands, arms and trouser legs ... .wasps fly as long as the temp is 46 oF or more , even at night if there is enough moonlight or street lighting , they also like to crawl upwards so tape off trousers into wellies , marigolds or thicker into cuffs and wear a brimmed hat with a fine mesh dark netting over it well tucked into thick clothing (I found all that out the hard way )
Another rotten skeg replaced in 31° sun.
Swap ya.
It's 1.2m of U section, with a plate holding the lower pivot, which I reclaimed from the old one and welded on.Swap ya.
It’s 12 here today. Only thing I dislike about this place. Sun is much better for someone who’s been smashed up lots!! Being young and stupid
Anyhow. Back on topic. Is that Skeg a bolt on? Never seen one like that. Usually weld on but I’ve never had anything to do with river boats
Swap ya.
" Evie M " My great niece's name & surname initial.Got the third chute welded up, tubes all welded up and welded to the strippers then the chutes welded to them.
One of those twins seems to be the favourite judging by the relative amount of representation!The Skipper has twins, Evie and Marshal hence the Evie M.
Nah, think it just sounded better than any other mix.One of those twins seems to be the favourite judging by the relative amount of representation!
