Mike Pinches
- North Wales
You can use oven cleaner to remove the aluminium transfer off the cylinder wall. Once the transfer has been cleaned off a quick 'hone' with some 400grit wet and dry, and the original cylinder will be to be re-used.I’ve turned this Husqvarna 254
Into this and box of bits!
Carb needs a clean and rebuild. Sadly the piston is junk, cylinder is marked but I can’t feel them with my fingers. Replacing both. Hoped to keep as much of it original as I could.
I used to fix saws professionally and have never had an OE cylinder that has had the actual bore damaged in a seize. The plated bores are very resilient and far tougher than the piston so what you feel on the cylinder is molten aluminium stuck to the wall rather than gouges out of it. Chinese replacement cylinders are a complete lottery, most of them being rubbish. If you must get a replacement cylinder then Meteor are ok, I tend to use Meteor pistons for rebuilds.
