Sergei Slovenija
- Slovenija Ljubljana
Parts #2Matryoshka principle: reworking the valve, the inner diameter should smoothly change from 225 to 204 mm. Type-setting insert 70 mm high, made of 10 mm thick plates and a pipe section. TIG welding, angle grinder, lathe and laser cutting. Parts #1.
View attachment 411060 View attachment 411061 View attachment 411062 View attachment 411063 View attachment 411064
Made a few rests forthe benches today. Threatened to do it a while back but I needed something "suitable" which turned out to be the bottom leg for adustable scaffoldi ng. I know, but these guys could break a cannonball!View attachment 411102
Then, continuing my mission of trying to actually finish some jobs I determined to finish cutting the large bit of rail track into two smaller bits. This is where it went a bit south. My pal realised something was up when all the sparks were going skywards, he came over explaining the grinder should be going the other way, go on then, have a go:
As yiu can see, he had to press the trigger with his thumb, it really could do with being turned 180 degrees to have the trigger in the proper orientation. If anyone has any suggestions I would welcome them. Meanwhile, finished the job so result anyway.
Aye looks like that is what has happened, someone has had the gearbox off and put it back 90 degrees out .Does the gearbox have 4 screws you can remove them rotate it
Do you live in Alaska.
That's alot of work to "make a start on this tonight"
Thats quite impressive
Better that than one who is always pointing and picking.I'm not saying my Mrs isn't very observant, but I reckon I could drill enough holes to make this place look like a Swiss cheese and it would still be months before she noticed.
In fact I'm pretty sure it would take her a couple of weeks to notice if I didn't come back in from the shed. That's true love for you (or something).![]()
Yes, wasn't expecting it to come out so well and also wasn't expecting the possibility to have black lines or white infill depending on settings.Thats quite impressive
Does it take much material off? would it be durable outside in the weather or would it fade quickly?Yes, wasn't expecting it to come out so well and also wasn't expecting the possibility to have black lines or white infill depending on settings.
