If anybody wants a nice cookie recipe I can recommend the Pret a Manger one:
Pret reveals their secret chocolate chip cookie recipe and it's super easy
Missing picking up a Pret a Manger chocolate chip cookie on your lunch break? Now you can make them at home with their secret recipewww.marieclaire.co.uk
Appropriate choice of material for brass monkey weathercomplete with machining marks because the garage was absolutely bloody freezing and my toes would have dropped off had I stayed out there to dress it up further.![]()
As well as the cam mentioned above, also have a look at the drum / shoes to get the best possible contact area and the lever ratios for pedal and drum ends of the brake.A new rear brake arm for my old BSA 250. doing everything I can to make the brakes better and the old arm went up (out of the way) which meant the brake rod had to bend round the shock. I’ve seen some like this so thought I’d swap it over .
View attachment 426690View attachment 426691View attachment 426692View attachment 426694View attachment 426695
Thanks Richard M (and Farside). Cams symmetrical as are the shoes. It’s a C15 trials with D7 Bantam hubs so the front is also SLS. Think I’ve got the geometry sussed. I’ll see how the shoes bed in and go from there. I’m also changing the arm on the brake pedal. The original (DIY) arrangement had the pedal pivot and pedal to rod joint in line with the rod as well as a slow bend in the rod to get round the shock. Pedal went down about 6” before it did anything. Nearly went into the front of a car a while back as we were both going a bit too quick down a narrow lane. Prioritising getting the brakes to work as well as I can over any trials riding consideration.As well as the cam mentioned above, also have a look at the drum / shoes to get the best possible contact area and the lever ratios for pedal and drum ends of the brake.
TLS front brake?
Is there enough clearance between the new arm and the chain adjuster ? Probably but looks close.A new rear brake arm for my old BSA 250. doing everything I can to make the brakes better and the old arm went up (out of the way) which meant the brake rod had to bend round the shock. I’ve seen some like this so thought I’d swap it over .
hi, yes plenty of clearance around the chain adjuster which is why it’s kicked out. I was expecting comments about it not being a good idea to lower it for trials use which is why I said that I was putting brake performance above trials riding considerations. I’ll be doing a mix of road and greenlane riding and the odd bit of trials. Not really sure yet. It’s a work in progress and no doubt this set up will not be foreverIs there enough clearance between the new arm and the chain adjuster ? Probably but looks close.
Just noticed that you will be riding it in trials, the reason for it to be routed above the swinging arm is to avoid contact with the sections and get damaged . Not a good idea to lower it IME.
Also I never felt the need for a good rear brake anyway especially off road but that is really a personal thing , Thinks! I never used one when road racing either ,too many other controls to worry about.
ha ha that last part is easier said than done!Working on the floor is no fun, especially as you get older. I've been making work benches recently and it's a bit of a revelation. I know it's obvious, but free bench space can end up being a luxury when you're in the habit of just acquiring a little more stuff all the time to do things better and more efficiently.
You'll end up doing more because you're comfortable and not bent over all the time.
Just keep it clear and don't cover it in crap.![]()
Insanity is doing the same thing again and again and expecting a different result.
