I finished the re-plumbing of the Citroen DS suspension today. It has taken several weeks. My thumbs are sore from bending the Kunifer pipes. The pipes need a special flaring tool and dies. It puts a bulge about 12mm from the end and also reduces the diameter of the tube for the last 2mm. A rubber seal pushes onto the pipe. With the pipe properly installed, the flare nut doesn't have to be apprentice tight. As the hydraulic pressure builds up, the rubber seal deforms and improves the seal.Now I have to fit the return pipes, these are nylon, low pressure and return any leaking hydraulic fluid back to the reservoir.
View attachment 437818View attachment 437821
Those flared return pipes on the plastic Citroen suspension tubes were the bane of our lives they always kept coming apart if we hit a hump or sleeping policeman hard . We had three Citroens at the timeI finished the re-plumbing of the Citroen DS suspension today. It has taken several weeks. My thumbs are sore from bending the Kunifer pipes. The pipes need a special flaring tool and dies. It puts a bulge about 12mm from the end and also reduces the diameter of the tube for the last 2mm. A rubber seal pushes onto the pipe. With the pipe properly installed, the flare nut doesn't have to be apprentice tight. As the hydraulic pressure builds up, the rubber seal deforms and improves the seal.Now I have to fit the return pipes, these are nylon, low pressure and return any leaking hydraulic fluid back to the reservoir.
Could you not just bolt on a U shaped counter weight in the two free holes so it lies inside the chuck jaw free space ?My lathe does not like unbalanced turning. Max of 300rpm set up like this. I may have to drilla dn tap chuck to allow counter weights next time.
I have used stud lock on the threads. Abiut to start turning the pivot.
I may have to drill and tap chuck to allow counter weights next time.
Bigger lathe wouldnt have noticed the imbalance.My lathe does not like unbalanced turning. Max of 300rpm set up like this. I may have to drilla dn tap chuck to allow counter weights next time.
in progress.Marking the holes for connecting the vice and part of the cross lathe support. 7 pies M6 imbus bolts should be enough.
View attachment 437777 View attachment 437779
I'm intrigued by the smoke stack 'u' pipe and how will you rod the smaller pipes.OK I've completed the welding and made my first fire. No smoke leaks!
You've heard of MIG like TIG, I present MIG like Stick:
Still need to disassemble and paint it with proper paint, and maybe clean up behind the stove while I am at it. And fit the flue gas thermometer so I can see what the difference is from before. It does put out a lot of heat I can tell just by standing near it.
Nah, don't have one of themWheelie bar for the Transalp?
