Now if that was me the draught from the gun would have blown the first one off the cup, or even worse, while spraying the last one, I would have knocked over the first...More Mini part painting.
Fear not! I tapped the cups to the table and the arches to the cups.Now if that was me the draught from the gun would have blown the first one off the cup, or even worse, while spraying the last one, I would have knocked over the first...
Done well to bend that three quater round cold1/4" thick plate keyholes on the CNC plasma (100 amps, 40 ipm)
3/4" dia. HR bar bent cold on a HF imported bender (was at the tool's limit for sure)
And some 2 x 2 x 1/8 wall box tube....View attachment 446806View attachment 446807View attachment 446808
He unfortunately caught on fire during the teaching session
Watch out those fridges on gas can be bloody dangerous.Today I made.... Holes! In the side of my campervan conversion.
There's something very "wrong" about cutting holes in perfectly sound panels!
But, my vintage 3-way fridge needs ventilation & an exhaust- so it had to be done.
I'd already built a new kitchen unit to align with the van inner framework, and insulated with PIR sides and top to segregate the ventilated area behind the fridge from the living space - so I made a few neasurements, slapped on some blue madling tape and had at it with a drill & a mini grinder.
The exposed cuts were painted with Bilt Hamber Electrox before the vents & exhaust were fitted.
Quite a faff to get the fridge electrics, exhaust connection, gas, and the gas connection for the grill and hob all hooked-up & tidied up - but it's all in (including lagging and segregating the hot & cold water pipes that run behind the grill pan & through the space behind & above the back of the fridge).
Still much to do, but I'm happy to get that part of the task out of the way.
(I'm on a budget, and had the fridge and sink/drainer/hob/grill which I've shortened to suit - but I actually like these old fridges - they are robust, quieter, very efficient and frugal to run compared to the pricey 12v compressor fridges that are in vogue - so I'd have fitted one anyway)
View attachment 446229View attachment 446230View attachment 446231
Trying to teach people stuff can be the most rewarding thing or the most frustrating... And sometimes both!Finished later at work this evening because I've spent a good half our teaching to a new employee how to cut with oxy propane .
Overall satisfied,I guess he has now forgiven me for being little bit bipolar, I've screamed at him when he tried to strike an hammer blow on another one ,in front of his face without glasses.
He unfortunately caught on fire during the teaching session , didn't listen at me when I've said that it was going to happen because he was right in front of the molten steel and sparks stream path .
It's funnier that I'm not younger in the shop but almost , and the apprentice is 10 years older than me.Trying to teach people stuff can be the most rewarding thing or the most frustrating... And sometimes both!
It is funny when some youths have no common sense and keep making silly mistakes... Eg one guy cutting some plate sat on forklift forks and managing to plasma halfway through one of the forks...
I agree. One of the first things machinists are taught - never leave the key in the chuck. Its a habit that is taught that takes a second and makes everyone a bit safer.It's funnier that I'm not younger in the shop but almost , and the apprentice is 10 years older than me.
Anyways it happened something similar to the forks , the bucket was on the stands, slightly tilted to not touch directly on them and not interfering with the cutting .
The stand deflected the spark stream directly towards him.
But there is an huge amount of things we have pay attention every single day.
It's not fun but I found myself saying to the least experienced what not to do safety wise , or correct the more experience mistakes or bad abits obviously without pronouncing a word, like when they left the key on the lathe chuck with motor turned permanently on .
I just pass by ,turn off the lathe and remove the key , I hate to see that.
Then after an half hour or more you can here someone "who turned off the lathe?"
The lathe used by the oldest and most experienced man at work doesn't have a clutch lever but an electric clutch.
Things fails once in a while ... And if I can reduce the probability of someone getting hurt by a flying key because a lathe was left on and the clutch failed....
Bit of weld, soon sort that...Eg one guy cutting some plate sat on forklift forks and managing to plasma halfway through one of the forks...
I'm a bit chunky kind of a kid....leaned into it.....Done well to bend that three quater round cold
Is it just me or does the loaf look sad and the choc cake looks happy
Either weld the chuck key to a big lump of metal after taking it out the chuck or take it out and chuck it in a bucket of dirty oil or if there is one the cutting fluid tank.It's funnier that I'm not younger in the shop but almost , and the apprentice is 10 years older than me.
Fire is soooo over rated.....No worries until it smells like a steak on the grill in the shop.He unfortunately caught on fire during the teaching session , didn't listen at me when I've said that it was going to happen because he was right in front of the molten steel and sparks stream path .
Yesterday Fizzy made magic smoke when he fired up his welder . At first he didn't see it as he was masked up about to carry on welding . I got him to stop within a second or so and the welder sent out enough smoke signals to tell the guys at the battle of little big horn to go home and not bother . Tonight the smoke machine refused to come apart , tomorrow Mr Dremel will take charge and grind at the corroded nuts & bolts holding the casings togetherFire is soooo over rated.....No worries until it smells like a steak on the grill in the shop.
Do you mean from CO poisoning, explosion, both?Watch out those fridges on gas can be bloody dangerous.
